@Ginmarr:
Danke für die Screenshots
(und den Link). Sehr aufschlussreich. Also kommt wohl ein Paperlaunch mit Vega zum 31.5. (Computex) und anschließenddem langsam in die Shops tröpfeln im Mitte-Ende Juni wie es aussieht.
EDIT: Das hier klingt auch interessant von ihm:
Und:
Ähnlich "skalar" aufgebaut wie Ryzen ? --- Hmmmm..
The new geometry pipeline in Vega was designed for higher throughput per clock cycle, through a combination of better load balancing between the engines and new primitive shaders for faster culling. As a programmer you shouldn't need to do anything special to take advantage of these improvements, but you're most likely to see the effects when rendering geometrically complex scenes that can really push the capabilities of the hardware.
Und:
Vega is both a new GPU architecture and also completely new SOC architecture. It's our first InfinityFabric GPU as well
