Athlonscout
Rear Admiral
- Jan. 2008
Luftschlösser baut wohl eher Nvidia mit ihrem überteueren G-Sync Platinen.
Niemnd hat behauptet, dass es allein mit VBLANK getan ist:
Quelle
Ergo baut FreeSync komplett auf bereits bekannten Industriestandards auf.
Somit ist DP 1.3 zwingend erforderlich, es sei denn entsprechende Steuerungselektronik wurde schon jetzt von dem ein- oder anderen Hersteller verbaut, was, wenn man Herrn Koduri glauben schenkt, bereits bei einigen auf dem Markt befindlichen Monitoren der Fall ist.
All that is needed for this to work, as AMD explained it, was an eDP(embedded Displayport) connection between the discrete GPU and the display, a controller for the screen that understands the variable refresh rate methods of eDP 1.0 specifications and an updated AMD driver to properly send it the signals. The panel can communicate that it supports this variable refresh technology to the graphics card through the EDID as resolutions and timings are communicated today and then the graphics driver would know to send the varying vblank signals to adjust panel refresh times on the fly.
If you aren't familiar with eDP, don't feel bad. It's a connection type used in tablets and notebooks and isn't used at all in desktop configurations (some all-in-one designs do use eDP). But here is where it might get interesting: the upcoming DisplayPort 1.3 standard actually includes the same variable refresh rate specification.
Quelle
