U
unreality
Noch was interessantes:
Techpowerup hat ja gar niedrigere temperaturen beim haswell als beim ivy gemessen:
dazu dieses zitat vom tester auf die frage wie is mit dem verbrauch aussieht
Habe allerdings auch schon von Retails aus Amerika gelesen die sehr heiß werden. Mal schauen.. Ist ja echt Chaos pur. Ich finde leider irgendwie kaum Reviews von normalen Nutzern mit ihren Retailexemplaren.
man könnte meinen die ES Samples von Intel haben Temperaturprobleme, die Retailverkaufsversionen vielleicht (hoffentlich!) weniger.Idle is comparable or lower than IVB. Load is a bit higher, due to the iVR, but actual CPU consumption is roughly less. I measure power for board reviews via the 8-pin EPS connector only, while I see some sites reporting full system numbers of ES CPUs that match my retail CPU figures via the 8-pin, and since they did not reach higher overclocks than I did(which a CPU with better power consumption should, based on my own samples), I have to question their results.
I have had three chips, two I still have in my possession, and both are retail.
Review using ES are kinda BS, in my books. I don't have any NDA with Intel, so I could tell you the differences between retail and ES, and they are quite big differences, but I'll leave that up to sites that used ES chips for review. All of TPUs reviews were done with retail chips.
