ASRock Latest Beta BIOS Update
| Model | Version | Date | Description | Download |
| 7.20 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| L1.42 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 | Download | |
| L2.22 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU | Download | |
| L1.92 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU | Download | |
| L2.32 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU | Download | |
| L4.34 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download | |
| L1.51 | 5/25/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download |
| X370M Pro4 | 7.30 7.0 Bridge | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. | Download |
| 7.03 | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. | Download | |
| 7.20 | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. | Download | |
| 7.30 | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 7.10 | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 4.49 | 5/27/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 | Download | |
| 7.20 | 5/27/2022 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 2. Support Renoir, Vermeer, and Cezanne CPU 3. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
