Tanzmusikus
- Aug. 2010
... oder sie haben es vergessen zu markieren.Lonex88 schrieb:Asrock hat jetzt die Beta von Bios Version 3.20 beendet
| Model | Version | Date | Description | Download |
| 3.20 | 2/25/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 3.20 | 2/24/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 3.20 | 2/27/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 3.20 | 2/26/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 3.20 | 3/4/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 3.20 | 3/4/2025 | Improve minority proportion of AMD 9000 series CPU boot issue | Download | |
| 3.20 | 3/3/2025 | Improve minority proportion of AMD 9000 series CPU boot issue. | Download | |
| 4.10 | 2025/3/21 | 12.72MB | Instant Flash[IMG]https://www.asrock.com/images/icon-help.png[/IMG] | Optimize system compatibility | [IMG]https://www.asrock.com/images/dl-blue.gif[/IMG] Global | [IMG]https://www.asrock.com/images/dl-yellow.gif[/IMG] China |
| 10.41 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **User will not able to flash previous BIOS once upgrading to this BIOS version | Download | |
| 10.41 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. ***ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. **** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 10.41 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 10.41 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 3.61 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Ryzen 5000 G-Series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU | Download | |
| 5.65 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download | |
| 5.65 | 4/9/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download |
| 3.61 | 4/10/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU | Download | |
| 5.65 | 4/10/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. *If you use Pinnacle Ridge or Picasso, please use ASRock Flashback function to update this BIOS. | Download | |
| 5.65 | 4/10/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download | |
| 5.65 | 4/10/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download | |
| 3.61 | 4/11/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *To support Ryzen 5000 G-Series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. | Download | |
| 3.61 | 4/14/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E | Download | |
| 10.41 | 4/14/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 10.41 | 4/22/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 10.41 | 4/22/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E | Download | |
| 10.41 | 4/21/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
| 10.41 | 4/21/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 10.41 | 4/21/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E | Download | |
| 3.61 | 4/18/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E | Download | |
| 10.41 | 4/18/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E | Download | |
| 10.41 | 4/18/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 10.41 | 4/23/2025 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.E *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Download | |
Looniversity schrieb:
