Catalyst 5.13 Final erschienen!
Hanskult
Mai 2005
Der Treiber ist jetzt draußen!
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/Catalyst_513_release_notes.html
Issues Resolved in Catalyst® Software Suite 5.13
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst®. These include:
* F.E.A.R: Slow game performance is no longer noticed when using CrossFire. Further information on this resolved issue can be found in topic number 737-21270
* The Video Preview no longer fails to change to its default settings when swapping the display mappings using the Catalyst® Control Center. Further information on this resolved issue can be found in topic number 737-21174
* Attempting to stretch the display horizontally using the Catalyst® Control Center, no longer results in the horizontal stretch mode failing to be applied unless the display is stretched vertically first. Further information on this resolved issue can be found in topic number 737-21175
* The PowerPlay™ option found in the Catalyst® Control Center no longer defaults to the enabled state after initial install of the display driver for systems containing an ATI Radeon® Xpress 200 series product. Further information on this resolved issue can be found in topic number 737-21180
* Auto-detect no longer fails to be applied as the default setting for the Deinterlacing option when first entering the Video aspect page of the Catalyst® Control Center. Currently the option is set as Weave. Further information on this resolved issue can be found in topic number 737-21185
* Catalyst® Control Center: Attempting to extend the desktop display when using a CRT, TV and DFP display devices no longer results in display corruption being noticed on the primary display adapter. Further information on this resolved issue can be found in topic number 737-20982
* Attempting to set the CRT as the primary display device after hot-plugging a DFP display device and enabling extended desktop mode, no longer results in the CRT failing to be set as the primary. Further information on this resolved issue can be found in topic number 737-21269
* Catalyst® Control Center: Entering the Overdrive™ aspect and changing the GPU setting to 509 and the memory setting to 505 no longer results in color corruption and the Windows XP operating system rebooting. Further information on this resolved issue can be found in topic number 737-21229
Thnx für die Info.....
Leider kommt aber unter deinem Link
Unauthorized download
We're sorry, but this download request cannot be authorized. As an option, you may visit any of the pages below for information about ATI services and products:
ati.com home
Connect to ATI's latest information.
Customer Care
Access technical support, drivers, and frequently asked questions.
Wenn du noch einen hättest der funktioniert ;)
DingMan
Ist BF2 immernoch verbugged mit dem?
Wo finde ich eigentlich den Mobility Treiber des 5.13?
Während auf der Homepage von ATI nur diese - nicht funktionierende - "Installation Verification Software" vorzufinden ist, hat ComputerBase nachher wahrscheinlich schon wieder den richtigen Download Link.
Wo findet ihr den immer?
Das der so einen Leistungsvorteil für ältere karten bringt hätte ich nicht gedacht!
Hm, der Leistungsschub hört sich ja gut an. :)
Aber wie sieht das nun aus mit dem Control Panel, gibt es das garnicht mehr?
Oder kann ich das ganze mit einem Trick behalten?
Wenn Du mir jetzt noch erklärst, in welchem Menü Du den Download-Link gefunden hast, bin ich zufrieden :)
Den Link habe ich in einem News - Beitrag auf ComputerBase gefunden! :D
danke schonmal
aber auf einem NON Dual CPU Kern
kann man auch mit ner X800 PRO von Performance Verbesserung sprechen bei FARCRY, DOOM3, RIDDICK, FEAR; COD 2 ????
oder insgesamt bei nicht messbarer Leistungssteigerung ?
Wer hat bereits getestet mit ner X800 xx Karte ?
Update:
PS : Die Leistungssteigerung soll nur DUAL CORE CPU´s betreffen- laut diversen Foren ?
Stimmt dies ?
Hoffe doch nicht .... :D
@Detonator: Auch wenn ich dem nicht so ganz folgen kann, bedanke ich mich schonmal!
@horn 29: Bei mir haben sich die Ergebnisse kaum verbessert.
Maximal 50 3DMarks...
Insgesamt also nicht der Rede Wert.
Hat sich erledigt:
Durch genaueres hinsehen des v5.12 konnte ich den Ordner WDM_ALL angucken und der Inhalt ist genau das was ich auch seperat downloaden kann.
Und wenn man den WDM Treiberinhalt (wo Setup mit steht) in einen Ordner im Cata v5.13 kopiert und dieser WDM_ALL heist nimmt die Installroutine des v5.13 die WDM Treiber mit in die Installation.
Also bei mir funzt das mit dem CCC schonmal nicht...
Hab das .NET Framework installiert und das CCC Package 5.13.
ABer das CCC startet nicht, sondern bleibt bei dem schwarzen Startbildschirm hängen. AUßerdem sind die Farben verfälscht...
Um das CCC zu starten muss auf alle Fälle das Microsoft .NET Framework 1.1 installiert sein. Mit dem Microsoft .NET Framework 2.0 allein, funktioniert das CCC nicht.
Wie jetzt ? Für CCC geht nur Framework 1.1 ? :confused_alt:
hä wieso? ich dachte, dass das .NET framework 2.0 alle funktionen der version 1.1 enthält?
