Nilson
Grand Admiral
- Dez. 2008
Hi,
Mein Linux Mint (22.1) bietet mir die Installation von Kernel 6.14 an. Aktuell läuft noch 6.11.0-29.
Die Installation von 6.14 (sowohl 6.14.0-24 als auch 6.14.0-27) bricht kurz vor dem Ende ab ("Running post installation triggers")
Hier erstmal der Log
hier die im log erwähnt "make.log"
Installation über die GUI (Update Manager -> Kernels)
Ältere Versionen von 6.11 und 6.8 kann ich ohne Probleme installieren.
Kann da einer vor euch herauslesen, was genau die installation fehlschlagen lässt?
Wenn ihr noch weiter Infos braucht, lasst es mich wissen.
Code:
installArchives() failed: Selecting previously unselected package linux-headers-6.14.0-27-generic.
(Reading database ...
(Reading database ... 5%%
(Reading database ... 10%%
(Reading database ... 15%%
(Reading database ... 20%%
(Reading database ... 25%%
(Reading database ... 30%%
(Reading database ... 35%%
(Reading database ... 40%%
(Reading database ... 45%%
(Reading database ... 50%%
(Reading database ... 55%%
(Reading database ... 60%%
(Reading database ... 65%%
(Reading database ... 70%%
(Reading database ... 75%%
(Reading database ... 80%%
(Reading database ... 85%%
(Reading database ... 90%%
(Reading database ... 95%%
(Reading database ... 100%%
(Reading database ... 802805 files and directories currently installed.)
Preparing to unpack .../linux-headers-6.14.0-27-generic_6.14.0-27.27~24.04.1_amd64.deb ...
Unpacking linux-headers-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Selecting previously unselected package linux-modules-6.14.0-27-generic.
Preparing to unpack .../linux-modules-6.14.0-27-generic_6.14.0-27.27~24.04.1_amd64.deb ...
Unpacking linux-modules-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Selecting previously unselected package linux-image-6.14.0-27-generic.
Preparing to unpack .../linux-image-6.14.0-27-generic_6.14.0-27.27~24.04.1_amd64.deb ...
Unpacking linux-image-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Selecting previously unselected package linux-modules-extra-6.14.0-27-generic.
Preparing to unpack .../linux-modules-extra-6.14.0-27-generic_6.14.0-27.27~24.04.1_amd64.deb ...
Unpacking linux-modules-extra-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Setting up linux-headers-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 6.14.0-27-generic
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module:
Cleaning build area...
make -j24 KERNELRELEASE=6.14.0-27-generic -C /lib/modules/6.14.0-27-generic/build M=/var/lib/dkms/hid-xpadneo/v0.9-171-g73be2eb/build/src VERSION=v0.9-171-g73be2eb modules...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.14.0-27-generic (x86_64)
Consult /var/lib/dkms/hid-xpadneo/v0.9-171-g73be2eb/build/make.log for more information.
dkms autoinstall on 6.14.0-27-generic/x86_64 failed for hid-xpadneo(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
* dkms: autoinstall for kernel 6.14.0-27-generic
...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.14.0-27-generic (--configure):
installed linux-headers-6.14.0-27-generic package post-installation script subprocess returned error exit status 11
Setting up linux-modules-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Setting up linux-modules-extra-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
Setting up linux-image-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
I: /boot/vmlinuz.old is now a symlink to vmlinuz-6.11.0-28-generic
I: /boot/initrd.img.old is now a symlink to initrd.img-6.11.0-28-generic
I: /boot/vmlinuz is now a symlink to vmlinuz-6.14.0-27-generic
I: /boot/initrd.img is now a symlink to initrd.img-6.14.0-27-generic
Processing triggers for linux-image-6.14.0-27-generic (6.14.0-27.27~24.04.1) ...
/etc/kernel/postinst.d/dkms:
Building module:
...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.14.0-27-generic (--configure):
installed linux-image-6.14.0-27-generic package post-installation script subprocess returned error exit status 11
Errors were encountered while processing:
Building module:
...fail!
Building module:
...fail!
Code:
DKMS make.log for hid-xpadneo-v0.9-171-g73be2eb for kernel 6.14.0-27-generic (x86_64)
Thu Aug 7 09:47:50 PM CEST 2025
make: Entering directory '/usr/src/linux-headers-6.14.0-27-generic'
make[1]: Entering directory '/var/lib/dkms/hid-xpadneo/v0.9-171-g73be2eb/build/src'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
You are using: gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
cp hid-xpadneo.c xpadneo.c
CC [M] xpadneo/core.o
CC [M] xpadneo/consumer.o
CC [M] xpadneo/keyboard.o
CC [M] xpadneo.o
xpadneo.c:1299:25: error: initialization of ‘const __u8 * (*)(struct hid_device *, __u8 *, unsigned int *)’ {aka ‘const unsigned char * (*)(struct >
1299 | .report_fixup = xpadneo_report_fixup,
xpadneo.c:1299:25: note: (near initialization for ‘xpadneo_driver.report_fixup’)
cc1: some warnings being treated as errors
make[3]: *** [/usr/src/linux-headers-6.14.0-27-generic/scripts/Makefile.build:207: xpadneo.o] Error 1
make[2]: *** [/usr/src/linux-headers-6.14.0-27-generic/Makefile:2002: .] Error 2
make[1]: *** [/usr/src/linux-headers-6.14.0-27-generic/Makefile:251: __sub-make] Error 2
make[1]: Leaving directory '/var/lib/dkms/hid-xpadneo/v0.9-171-g73be2eb/build/src'
make: *** [Makefile:251: __sub-make] Error 2
make: Leaving directory '/usr/src/linux-headers-6.14.0-27-generic'
