ASRock Latest Beta BIOS Update
| Model | Version | Date | Description | Download |
| 5.18 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 | Download | |
| 4.25 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 5.35 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 3.01 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 4.25P | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 for Pink Edition *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 2.85 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 4.86 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 5.18 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 4.66 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 4.49 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system. *Before updating this BIOS, please also read the description in previous BIOS version. | Download | |
| 3.59 | 2/9/2022 | Update AMD AM4 AGESA Combo V2 PI 1.2.0.5 *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. *To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU. *If you use Pinnacle Ridge or Picasso, please use ASRock Flashback function to update this BIOS. | Download | |
