CPU running at 0,40GHz after upgrading motherboard
Status
imsorry
Cadet 1st Year
Jan. 2021
  • Prozessor (CPU): AMD Ryzen 5 4500
  • Arbeitsspeicher (RAM): 2x Nanya 8192MB 3200MHz
  • Mainboard: Asus Prime A520a-m II
  • Netzteil: CSL 500W
  • Gehäuse: tower/cube
  • Grafikkarte: Geforce RTX 3050
  • HDD / SSD: 1x HDD 2TB, 1x NVMe m.2 KIOXIA Exceria SSD 500GB
  • Weitere Hardware, die offensichtlich mit dem Problem zu tun hat (Monitormodell, Kühlung usw.):
Hello, so ive wanted to upgrade my motherboard from an Asus Prime A320m-k to a Asus Prime A520m-a II. Ive encountered so many problems with doing that, its unbelievable. (im doing this for a friend). ive built and rebuilt computers for almost 8 years now every now and then, but now im almost 3 days in and i cant find the problem.
at first it was bitlocker, we got that solved. (i removed bitlocker from the HDD and the NVMe for clarification)
then it was the NVMe at 0-2% speed and the GPU also at 0-2%.
then ive reinstalled windows from the media creation tool because i thought the reinstall wasnt clean.
now my cpu is running constantly at 0.40GHz, all the time.
ive checked bios, did a cmos reset, updated the bios firmware, installed the chipset driver, quadruple checked the wiring, took the cpu out and placed it back in with new thermal paste. replaced the GPU in and out the PCIex16 slot, same with the NVMe. checked the HDD. ive basically checked everything there is to check multiple times. (if not please tell me what else there is)
i do not know what to do anymore. only thing i can imagine is the power supply is faulty or the "new" motherboard came damaged.
i have a spare 600W bequiet PSU home if this helps?
-cpu temp is okay
ive also noticed my gpu isnt showing up in task manager anymore (it showed up before the clean windows install)
maybe also noteworthy is that everything (i mean everything) is extremely slow.
one windows reinstall almost took 4 hours. i cant use microsoft edge without waiting 2 mins for a tab to open.
everything is just slow.
any help is appreciated, ty
Can you go back to the old board while keeping all other hardware and the currently problematic Windows install to check if the symptoms persist?
Reaktionen: Baal Netbeck
Did you plug in the EPS?
How much did you tighten the cooler?
Sometimes I have the same problem with my laptop (also extremely slow). When I start it from battery. Mostly it gets normal when I put in the power plug. Sometimes I have to re-start it.
You did some bios reset. Checked the cpu settings? Maybe some (extreme) power saving settings?
Or try loading default settings, next time failsafe settings.
edit:
Did you try some linus boot stick just to see everything is normal there?
Reaktionen: ruthi91
Why did you do that? Where there any Probs with your old Motherboard?
No problems there while update? I would flash the bios again.
Die Sache mit den 0,4GHz hört sich an nach einem Problem mit den Spannungswandlern irgendwie.
Daten von HWInfo im Sensoren modus könnten helfen etwas mehr Licht in die Situation zu bringen.
(Just translate)
Reaktionen: xXDariusXx, Baal Netbeck und Azghul0815
Oder falsche Werte im BIOS z.B nicht richtig erkannte CPU oder falsch Optimiert
Reaktionen: Alexander2
The first thing I would do is double-check that the latest BIOS is installed.
Version 3636 dated 03.02.2026 see
https://www.asus.com/de/supportonly/prime a520m-a ii/helpdesk_bios/
And if in doubt, I would reinstall this BIOS. Make sure the BIOS is in its factory default state.
Are all standoffs between the motherboard and the case correctly positioned?
Keep in mind that the motherboard you bought could simply be defective.
Reaktionen: Baal Netbeck, Alexander2, Dr.Death und eine weitere Person
Gelöscht, hier stand Mist.
0.4GHz is a not-so-uncommon issue when laptops use battery charging limits.
Had this myself last weekend and googled it.
You course your desktop build does not use charging limits, but it makes the quoted statement plausible.
z-R-o- schrieb:
This way you can rule out whether it's due to the new motherboard or something else, such as a mistake you caused.
Die Frage war warum OP überhaupt sein Mainboard gewechselt hat.
@gaym0r
Dann habe ich da nicht richtig gelesen und was verwechselt. Dachte er hätte auf die Frage von @incurable geantwortet.
Reaktionen: gaym0r
As always, some pictures of the MB, CPU, PSU and wireing would be nice.
Sometimes, it is just a wrong plugging which is overseen ten times but the 11th user here can see it at first glance
@jo0 ist schon ein bisschen komisch
ich würde sagen
/close
/move /dev/null
Reaktionen: DJMadMax, jo0 und LuxSkywalker
EPS? sorry ive never heard of this, explain please.
not too tight, not too loose.
i can try that, im omw there any minute.
edit:
i checked the cpu settings, everything is okay in the bios. i checked if there is any power waving enabled, there isnt. maybe ive overlooked smth?
oh so windows safe mode??
do you mean booting linux up on a stick for reference to windws?
the old mb had problems with the GPIO (PCIEx16) slot, so we replaced it.
well i used ez flash 3 with the newest version. this specific mb supported the CPU since Ver. 2423, but it already came with a newer version than that. should i flash it again?
(Just translate)
ich hab noch ein bequiet was ich jetzt gleich mitnehmen werde.
ich poste davor ein foto von hwinfo, vielleicht hilft das bevor ich die PSU wechsle.
sure thing! im omw there rn, give me a bit
Reaktionen: IDontWantAName
@TorenAltair its plugged in. here are pics from the pc inside and the HWINFO
  • HWMonitor.txt
    HWMonitor.txt
The CPU only gets 0.74V and the internal GPU isn‘t recognized either. Try to flash the UEFI with the latest version and load default settings after reboot. Then check the settings for CPU in the UEFI.
Da fehlen Befestigungsschrauben am MB.
Abstandshalter sind drunter?
Reaktionen: Volvo480, motorazrv3, UK Monkey und eine weitere Person
Status
