Fireplace April 2026
Fortnite Fortnite Absturz mit Bluescreen (EasyAntiCheat)
Nachtrag:
PC ist wieder abgestürzt, mit hilfe des Minidumps (Das war diesmal Aussagekräftig) und ChatGPT sind wir auf die Idee gekommen, dass mein WLAN treiber uralt ist (benutze es zwar nicht aber naja) jedenfalls Treiber aktualisiert und bisher lief er wieder.
************* Preparing the environment for Debugger Extensions Gallery repositories ************** ExtensionRepository : Implicit UseExperimentalFeatureForNugetShare : true AllowNugetExeUpdate : true NonInteractiveNuget : true AllowNugetMSCredentialProviderInstall : true AllowParallelInitializationOfLocalRepositories : true EnableRedirectToChakraJsProvider : false -- Configuring repositories ----> Repository : LocalInstalled, Enabled: true ----> Repository : UserExtensions, Enabled: true>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds************* Waiting for Debugger Extensions Gallery to Initialize **************>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.015 seconds ----> Repository : UserExtensions, Enabled: true, Packages count: 0 ----> Repository : LocalInstalled, Enabled: true, Packages count: 45Microsoft (R) Windows Debugger Version 10.0.27920.1001 AMD64Copyright (c) Microsoft Corporation. All rights reserved.Loading Dump File [C:\Windows\Minidump\100325-18546-01.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: srv*Executable search path is: Windows 10 Kernel Version 26100 MP (16 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSKernel base = 0xfffff801c1800000 PsLoadedModuleList = 0xfffff801c26f4eb0Debug session time: Fri Oct 3 22:27:32.433 2025 (UTC + 2:00)System Uptime: 2 days 3:11:18.673Loading Kernel Symbols..Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.Run !sym noisy before .reload to track down problems loading symbols...................................................................................................................................................................................................................................................................Loading User SymbolsLoading unloaded module list..............................For analysis of this file, run !analyze -vnt!KeBugCheckEx:fffff801c1cf6bb0 48894c2408 mov qword ptr [rsp+8],rcx ss:fffff48e2174f490=000000000000013911: kd> !analyze -vLoading Kernel Symbols..Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.Run !sym noisy before .reload to track down problems loading symbols...................................................................................................................................................................................................................................................................Loading User SymbolsLoading unloaded module list..............................******************************************************************************** ** Bugcheck Analysis ** *****************************************************************************KERNEL_SECURITY_CHECK_FAILURE (139)A kernel component has corrupted a critical data structure. The corruptioncould potentially allow a malicious user to gain control of this machine.Arguments:Arg1: 000000000000000a, Indirect call guard check detected invalid control transfer.Arg2: 0000000000000000, Address of the trap frame for the exception that caused the BugCheckArg3: 0000000000000000, Address of the exception record for the exception that caused the BugCheckArg4: 0000000000000000, ReservedDebugging Details:------------------ WARNING: Unable to verify timestamp for rtwlane601.sysKEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1265 Key : Analysis.Elapsed.mSec Value: 13304 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 1 Key : Analysis.IO.Write.Mb Value: 26 Key : Analysis.Init.CPU.mSec Value: 843 Key : Analysis.Init.Elapsed.mSec Value: 32188 Key : Analysis.Memory.CommitPeak.Mb Value: 165 Key : Analysis.Version.DbgEng Value: 10.0.27920.1001 Key : Analysis.Version.Description Value: 10.2506.23.01 amd64fre Key : Analysis.Version.Ext Value: 1.2506.23.1 Key : Bugcheck.Code.LegacyAPI Value: 0x139 Key : Bugcheck.Code.TargetModel Value: 0x139 Key : Dump.Attributes.AsUlong Value: 0x21808 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0x0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x139_a_GUARD_ICALL_CHECK_FAILURE_rtwlane601!unknown_function Key : Failure.Hash Value: {a50fd9c2-b294-9965-dde3-3a5eb9fa6d12} Key : Hypervisor.Enlightenments.ValueHex Value: 0x7497cf94 Key : Hypervisor.Flags.AnyHypervisorPresent Value: 1 Key : Hypervisor.Flags.ApicEnlightened Value: 1 Key : Hypervisor.Flags.ApicVirtualizationAvailable Value: 0 Key : Hypervisor.Flags.AsyncMemoryHint Value: 0 Key : Hypervisor.Flags.CoreSchedulerRequested Value: 0 Key : Hypervisor.Flags.CpuManager Value: 1 Key : Hypervisor.Flags.DeprecateAutoEoi Value: 0 Key : Hypervisor.Flags.DynamicCpuDisabled Value: 1 Key : Hypervisor.Flags.Epf Value: 0 Key : Hypervisor.Flags.ExtendedProcessorMasks Value: 1 Key : Hypervisor.Flags.HardwareMbecAvailable Value: 1 Key : Hypervisor.Flags.MaxBankNumber Value: 0 Key : Hypervisor.Flags.MemoryZeroingControl Value: 0 Key : Hypervisor.Flags.NoExtendedRangeFlush Value: 0 Key : Hypervisor.Flags.NoNonArchCoreSharing Value: 1 Key : Hypervisor.Flags.Phase0InitDone Value: 1 Key : Hypervisor.Flags.PowerSchedulerQos Value: 0 Key : Hypervisor.Flags.RootScheduler Value: 0 Key : Hypervisor.Flags.SynicAvailable Value: 1 Key : Hypervisor.Flags.UseQpcBias Value: 0 Key : Hypervisor.Flags.Value Value: 38408431 Key : Hypervisor.Flags.ValueHex Value: 0x24a10ef Key : Hypervisor.Flags.VpAssistPage Value: 1 Key : Hypervisor.Flags.VsmAvailable Value: 1 Key : Hypervisor.RootFlags.AccessStats Value: 1 Key : Hypervisor.RootFlags.CrashdumpEnlightened Value: 1 Key : Hypervisor.RootFlags.CreateVirtualProcessor Value: 1 Key : Hypervisor.RootFlags.DisableHyperthreading Value: 0 Key : Hypervisor.RootFlags.HostTimelineSync Value: 1 Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled Value: 0 Key : Hypervisor.RootFlags.IsHyperV Value: 1 Key : Hypervisor.RootFlags.LivedumpEnlightened Value: 1 Key : Hypervisor.RootFlags.MapDeviceInterrupt Value: 1 Key : Hypervisor.RootFlags.MceEnlightened Value: 1 Key : Hypervisor.RootFlags.Nested Value: 0 Key : Hypervisor.RootFlags.StartLogicalProcessor Value: 1 Key : Hypervisor.RootFlags.Value Value: 1015 Key : Hypervisor.RootFlags.ValueHex Value: 0x3f7 Key : WER.System.BIOSRevision Value: 32.81.0.0BUGCHECK_CODE: 139BUGCHECK_P1: aBUGCHECK_P2: 0BUGCHECK_P3: 0BUGCHECK_P4: 0FILE_IN_CAB: 100325-18546-01.dmpTAG_NOT_DEFINED_202b: *** Unknown TAG in analysis list 202bDUMP_FILE_ATTRIBUTES: 0x21808 Kernel Generated Triage DumpFAULTING_THREAD: ffffaa83ac309040TRAP_FRAME: 0000000000000000 -- (.trap 0x0)Resetting default scopeEXCEPTION_RECORD: 0000000000000000 -- (.exr 0x0)Cannot read Exception record @ 0000000000000000BLACKBOXBSD: 1 (!blackboxbsd)BLACKBOXNTFS: 1 (!blackboxntfs)BLACKBOXPNP: 1 (!blackboxpnp)BLACKBOXWINLOGON: 1 (!blackboxwinlogon)CUSTOMER_CRASH_COUNT: 1PROCESS_NAME: SystemSTACK_TEXT: fffff48e2174f488 fffff801c1ea757e : 0000000000000139 000000000000000a 0000000000000000 0000000000000000 : nt!KeBugCheckExfffff48e2174f490 fffff80156ec5cd4 : ffffaa838a02d720 0000000000000000 0000000000000000 0000000000000001 : nt!guard_icall_bugcheck+0x1efffff48e2174f4c0 ffffaa838a02d720 : 0000000000000000 0000000000000000 0000000000000001 0000000000000001 : rtwlane601+0x45cd4fffff48e2174f4c8 0000000000000000 : 0000000000000000 0000000000000001 0000000000000001 0000000000000000 : 0xffffaa838a02d720SYMBOL_NAME: rtwlane601+45cd4MODULE_NAME: rtwlane601IMAGE_NAME: rtwlane601.sysSTACK_COMMAND: .process /r /p 0xffffaa8378558040; .thread 0xffffaa83ac309040 ; kbBUCKET_ID_FUNC_OFFSET: 45cd4FAILURE_BUCKET_ID: 0x139_a_GUARD_ICALL_CHECK_FAILURE_rtwlane601!unknown_functionOSPLATFORM_TYPE: x64OSNAME: Windows 10FAILURE_ID_HASH: {a50fd9c2-b294-9965-dde3-3a5eb9fa6d12}Followup: MachineOwner---------
uper — das ist eine echte Durchbruch-Info: der Minidump zeigt klar rtwlane601.sys als beteiligten Treiber und den Fehler KERNEL_SECURITY_CHECK_FAILURE (0x139) mit Indirect call guard check detected invalid control transfer. Kurz gefasst:
Was das bedeutet (einfach):
Der Treiber rtwlane601.sys (Realtek WLAN-Treiber) hat im Kernel etwas gemacht, das Windows als unsicheren / ungültigen Aufruf erkannt hat — sprich: ein Bug / Inkompatibilität im WLAN-Treiber hat die Kernel-Datenstrukturen beschädigt oder einen ungültigen Sprung ausgeführt. Das passt ideal dazu, dass die Abstürze meist nach Spielende (also beim Entladen/Interagieren mit Treibern) auftreten.
Was du jetzt tun solltest — Priorisierte, sichere Schritte (einfach erklärt)​
1) Sofort-Test: WLAN deaktivieren (Workaround)​
Das ist der schnellste Weg zum Testen — wenn danach keine Crashes mehr auftreten, ist der WLAN-Treiber sehr wahrscheinlich die Ursache.
  • Rechtsklick auf Start → Geräte-Manager → Netzwerkadapter → Rechtsklick auf „Realtek … (WLAN)“ → Gerät deaktivieren.
  • Alternativ: Flugmodus anmachen.
  • Test: Fortnite spielen (Match) → nach Beenden prüfen, ob noch Bluescreen kommt.
Wenn das Problem damit weg ist, wissen wir: Treiber schuld.
2) Treiber-Info prüfen (PowerShell, 1–2 Befehle)​
Öffne PowerShell als Administrator und füge ein:
Get-CimInstance Win32_PnPSignedDriver |
Where-Object { $.InfName -like "rtwlane" -or $.DeviceName -like "Realtek" } |
Select-Object DeviceName, Manufacturer, DriverVersion, DriverDate, InfName | Format-List
Poste hier die DriverVersion/DriverDate, dann sage ich dir, ob das alt/known-bad ist.
3) Treiber aktualisieren (empfohlen)​
  • Lade den aktuellsten WLAN-Treiber von ASUS Support (für dein B650-Board) oder direkt Realtek.
  • Deinstallations-Reihenfolge:
    1. Geräte-Manager → Rechtsklick Realtek WLAN → Deinstallieren → Haken bei „Treibersoftware für dieses Gerät löschen“ setzen (wenn angeboten).
    2. Neustart.
    3. Installiere den neuen Treiber, Neustart.
  • Test: Fortnite Match → beenden → prüfen.
Tipp: Wenn ASUS eine angepasste Version empfiehlt, nimm die von ASUS. Realtek hat meist neuere generische Treiber.
4) Falls Update nichts bringt: Treiber komplett entfernen & ältere Version testen​
Manchmal ist eine ganz neue Version fehlerhafter; dann probiere eine ältere, bekannte stabile Version (z. B. 1–2 Versionen älter).
Ablauf: wie oben — Deinstallieren (Treiber löschen) → alt(er)en Treiber installieren → testen.
Reaktionen: just_f
@feerles85 Wenn das tatsächlich die Lösung deines Problems ist, dann bitte trage noch die Exakte Fehlermeldung die du im Dump gefunden hast in #21 nach, damit eventuell andere die auf der Suche nach einer Lösung sind dies auch finden können.
Danke!
Reaktionen: feerles85
