Alternate 1
PC ruckelt bei jeden 2. Start
redjack1000 schrieb:
Ahh ja Code 141 ddeutet darauf hin, das einen Fehler mit der GPU gab.
Lade mal den DUMP
in das Forum, da kann man mehr sehen.
CU
redjack
Ich kenne Debugging noch von meinen FreeBSD Serverb (gdb), kann ich irgendwelche privaten Infos leaken durch die dump datei auf Windows?
@redjack1000
Diff:
Mini Kernel Dump does not contain unloaded driver list
For analysis of this file, run !analyze -v
nt!DbgkpWerCaptureLiveTriageDump+0x8e:
fffff807`b24ffa5e 488b8788000000  mov     rax,qword ptr [rdi+88h] ds:002b:ffffb68c`fac16248=????????????????
7: kd> !analyze -v
Loading Kernel Symbols
Loading User Symbols
*                        Bugcheck Analysis                                    *
VIDEO_ENGINE_TIMEOUT_DETECTED (141)
One of the display engines failed to respond in timely fashion.
(This code can never be used for a real BugCheck; it is used to identify live dumps.)
Arguments:
Arg1: ffff9a8a862da2b0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8079516fc40, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, The secondary driver specific bucketing key.
Arg4: ffff9a8a7fcb2080, Optional internal context dependent data.
Debugging Details:
Unable to load image nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1265
    Key  : Analysis.Elapsed.mSec
    Value: 4373
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 34
    Key  : Analysis.Init.CPU.mSec
    Value: 687
    Key  : Analysis.Init.Elapsed.mSec
    Value: 55211
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 103
    Key  : Analysis.Version.DbgEng
    Value: 10.0.29507.1001
    Key  : Analysis.Version.Description
    Value: 10.2511.5.1 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2511.5.1
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x141
    Key  : Bugcheck.Code.TargetModel
    Value: 0x141
    Key  : Dump.Attributes.AsUlong
    Value: 0x18
    Key  : Dump.Attributes.KernelGeneratedTriageDump
    Value: 1
    Key  : Failure.Bucket
    Value: LKD_0x141_IMAGE_nvlddmkm.sys
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8079516fc40
    Key  : Failure.Exception.IP.Module
    Value: nvlddmkm
    Key  : Failure.Exception.IP.Offset
    Value: 0x19afc40
    Key  : Failure.Hash
    Value: {341dd0b3-9ebd-47a8-9de8-23f4b00fabbc}
    Key  : Faulting.IP.Type
    Value: Paged
BUGCHECK_CODE:  141
BUGCHECK_P1: ffff9a8a862da2b0
BUGCHECK_P2: fffff8079516fc40
BUGCHECK_P3: 0
BUGCHECK_P4: ffff9a8a7fcb2080
FILE_IN_CAB:  WATCHDOG-20260208-0501.dmp
DUMP_FILE_ATTRIBUTES: 0x18
  Kernel Generated Triage Dump
  Live Generated Dump
FAULTING_THREAD:  ffff9a8a72efd480
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
VIDEO_TDR_CONTEXT: dt dxgkrnl!_TDR_RECOVERY_CONTEXT ffff9a8a862da2b0
Symbol dxgkrnl!_TDR_RECOVERY_CONTEXT not found.
PROCESS_OBJECT: ffff9a8a7fcb2080
PROCESS_NAME:  System
IP_IN_PAGED_CODE:
nvlddmkm+19afc40
fffff807`9516fc40 ??              ???
STACK_TEXT:
ffffad88`5b5068d0 fffff807`b24fff69     : ffff9a8a`862da2b0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!DbgkpWerCaptureLiveTriageDump+0x8e
ffffad88`5b506e00 fffff807`b28a239a     : 00000000`00000000 00000000`00000000 fffff807`b28dbf00 00000000`c0000099 : nt!DbgkpWerProcessPolicyResult+0x21
ffffad88`5b506e30 fffff807`b28a2199     : 00000000`00000003 ffffad88`5b507010 ffff9a8a`862da2b0 ffff9a8a`78533d80 : nt!DbgkWerCaptureLiveKernelDump2+0x1ea
ffffad88`5b506e90 fffff807`43ff5f49     : ffffb68c`f9d4e050 ffffb68c`f9d4e050 ffffb68c`ee131312 ffff9a8a`862da2b0 : nt!DbgkWerCaptureLiveKernelDump+0x69
ffffad88`5b506f10 fffff807`46e52d69     : ffffad88`5b5071d0 ffff9a8a`72f4a000 00000000`00000000 00000000`00000001 : dxgkrnl!TdrCollectDbgInfoStage1+0xd69
ffffad88`5b5070d0 fffff807`46ea69d7     : ffff9a8a`72f4a001 ffff9a8a`72f4a6f8 00000000`00000001 00000000`00000001 : dxgmms2!VidSchiResetHwEngine+0x2c1
ffffad88`5b5072f0 fffff807`46eb1606     : ffffad88`00000000 ffff9a8a`72ebb000 ffffad88`5b507479 00000000`00000000 : dxgmms2!VidSchiResetEngines+0xcb
ffffad88`5b507340 fffff807`46e187ef     : ffff9a8a`72ebb000 00000000`00000000 ffffad88`5b507479 00000000`00000607 : dxgmms2!VidSchiCheckHwProgress+0x316
ffffad88`5b5073d0 fffff807`46eb1fc2     : ffff9a8a`72ebb000 ffff9a8a`72ead7b0 ffff9a8a`86188010 fffff807`46ea6ae9 : dxgmms2!VidSchiScheduleCommandToRun+0x5f
ffffad88`5b5074e0 fffff807`46ea6be1     : ffff9a8a`72ebb500 ffff9a8a`72ebb000 fffff807`46ea6b00 ffff9a8a`72ebb000 : dxgmms2!VidSchiRun_PriorityTable+0x42
ffffad88`5b507530 fffff807`b228c4da     : ffff9a8a`72efd480 fffff807`00000001 00000000`00000000 ffff8901`dcf11180 : dxgmms2!VidSchiWorkerThread+0xe1
ffffad88`5b507570 fffff807`b24a32d4     : ffff8901`dcf11180 ffff9a8a`72efd480 fffff807`b228c480 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
ffffad88`5b5075c0 00000000`00000000     : ffffad88`5b508000 ffffad88`5b501000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  nvlddmkm+19afc40
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
STACK_COMMAND: .process /r /p 0xffff9a8a63576040; .thread 0xffff9a8a72efd480 ; kb
FAILURE_BUCKET_ID:  LKD_0x141_IMAGE_nvlddmkm.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {341dd0b3-9ebd-47a8-9de8-23f4b00fabbc}
Followup:     MachineOwner
@qiller Ich kann leider nicht sagen ob der Absturz mit dem Fehler zutun hat, ich weiß das vor einer Weile mein PC beim starten ausgegangen ist aber bei dem Fehler um den es geht passiert tatsächlich nichts bis man den PC manuel neustartet, dem Threadersteller hat scheinbar auch keiner Helfen können, hab auch schon viel im Netz nachgesehen aber auch noch keine Lösung gefunden.
Dann bleibt nur, warten bis der Fehler auftritt und dann in die Fehlersuche einsteigen.
Cu
redjack
@redjack1000 Ich hab für mich jetzt mal XMP deaktiviert heute, mal schauen ob das etwas ändert.
Laut dem Netz und dem Threadersteller bringt das aber nichts und wenn ich drüber nachdenke dann glaube ich auch das bisher schon (mal) getan zu haben, ich werde Rückmeldung geben.
Ich kann nur sagen, dass ich das vom TE hier dargestellte Ruckeln kenne und es bei mir damals an massiven Problemen mit dem PCIe x16 Gen4 Betrieb des ersten PCIe Slots (PEG) lag. Was bei mir half:
  • anderen x16 PCIe-Slot verwenden (der dann nur mit x4 angebunden war)
  • im zweiten Slot einfach ne Netzwerkkarte eingesteckt, damit der PEG durch das Lane Sharing nur noch mit 8 Lanes angebunden war
  • im UEFI von Gen4 auf Gen3 runterstellen
  • ältere Gen3 Grafikkarte nutzen
  • Mainboard tauschen
Ich hab mich für letzten Punkt entschieden, weil ich durch ein billiges Austauschboard schon wusste, dass es am Mainboard lag. Das kann bei dir natürlich eine andere Ursache, z.B. die Grafikkarte selbst oder deren Sitz im Slot, haben.
Edit: Da die PCIe Lanes der Grafikkarte letztendlich in der CPU enden, kann es theoretisch auch am Sitz der CPU im Sockel liegen.
@qiller Mein PC wurde von Dubaro zusammen gebaut und ist knapp 4 Monate alt ( Ja ich hab keine Lust ihn zurück zu senden, dass dauert sonst eine ganze Weile oder sie können den Fehler nicht reproduzieren und mann muss die Reperatur selber zahlen )
https://imgur.com/a/5dloSDM kommt dir das Verhalten denn bekannt vor ? ( Man achte auch auf die Tastatur LED - ist mir eben erst aufgefallen ) ( Die Tastatur bei der letzten LED Einstellung laggt auch mit dem ganzen System )
Ja, etwas stärker noch bei mir und bei mir hat das die ganze Zeit so geruckelt, bei dir kommt er ja immer wieder mal zur "Besinnung". Fenster Verschieben ging nur mit 2 FPS oder so.
@qiller Die Frage ist, welcher deiner Lösungsvorschläge hilft mir jetzt vorallem wenn ich den Kolben bei Dubaro gekauft habe
@redjack1000 Ja die RGB Sachen habe ich erst seit kurzem, daran liegt es nicht
Stell halt im UEFI testweise auf Gen3 runter, das ist das einfachste. Und die Grafikkarte mal reseaten ist jetzt auch kein Hexenwerk. Aber wenn das ein PC von Dubaro ist, würde ich denen das Problem schildern, vlt. kennen die ja noch eine andere Ursache bzw. Problemlösung
Btw, noch alte Bilder von der RMA gefunden. So sah das bei mir damals aus:
defektes Board @Gen4defektes Board @Gen3Billig-Ersatz Board @Gen4RMA Austausch-Board @Gen4
