[Sammelthread] Intel Core 2 Duo/Quad übertakten - Beginnerfragen (FSB, BIOS, usw.) II
Status
Also ich habe mein System mit diesen Einstellungen ,mit Prime Small FFT und Large FFT 30 min. stabil.
Teste weiter noch 10St.
Wenn mir jemand noch Fein Korrektur vorschlagen kann wehre toll !
GIGABYTE Gigabyte GA-EP45-UD3R
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8x
Fine CPU Clock Ratio.....................:.+0.50
CPU Frequency ...........................: 3,520Ghz (415x8.5)
*** Clock Chip Control ***
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............:415Mhz
PCI Express Frequency (Mhz) .........:100Mhz
C.I.A. 2........................................:Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800mv
PCI Express Clock Drive.................: 900mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
*** DRAM Performance Control ***
Performance Enhance...................: [Turbo]
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............:2.66D
Memory Frequency (Mhz) ..............: 1100Mhz
DRAM Timing Selectable ................: Manuell
Standard Timing Control
CAS Latency Time........................: 5
tRCD .........................................: 5
tRP'...........................................: 5
tRAS..........................................: 15
Advanced Timing Control [Press Enter]
tRRD...........................................:Auto
tWTR..........................................:Auto
tWR............................................:Auto
tRFC...........................................:Auto
tRTP...........................................:Auto
Command Rate (CMD) ....................:Auto
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.........................: 8
tRD Phase0 Adjustmen....................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment ..................:Auto
tRD Phase3 Adjustment...................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
DDR3 Write Training........................:Enabled
Channel A Driving Settings [Press Enter]
Driving Strength Profile.................:Auto
Data Driving Pull-Up Level.............:Auto
Cmd Driving Pull-Up Level..............:Auto
Ctrl Driving Pull-Up Level.............:Auto
Clk Driving Pull-Up Level..............:Auto
Data Driving Pull-Down Level..........:Auto
Cmd Driving Pull-Down Level...........:Auto
Ctrl Driving Pull-Down Level...........:Auto
Clk Driving Pull-Down Level............:Auto
Channel B
Channel B Driving Settings [Press Enter]
Data Driving Pull-Up Level..............:Auto
Cmd Driving Pull-Up Level...............:Auto
Ctrl Driving Pull-Up Level................:Auto
Clk Driving Pull-Up Level.................:Auto
Data Driving Pull-Down Level...........:Auto
Cmd Driving Pull-Down Level............:Auto
Ctrl Driving Pull-Down Level............:Auto
Clk Driving Pull-Down Level..............:Auto
Motherboard Voltage Control
>>> CPU
Loadline Calibration.……….............. disabled !
CPU Vcore….……….......1.2500V...: 1.2750V
CPU Termination…..... 1.200V.......: Normal
CPU PLL…………………....1.500V.......: Normal
CPU Referen.…………....0.760V.......: 0.760v
>>> MCH/ICH
MCH Core…………….....1.100V...........: 1.100V
MCH Reference….…….0.760V...........: 0.760V
MCH/DRAM Ref.…......0.900V...........: Normal
ICH I/O……………….....1.500V............: 1.500V
ICH Core…………...……1.100V............: 1.100V
>>> DRAM
DRAM Voltage ……....1.800V............: 2.020V
DRAM Termination .…0.900V............: 1.010V
Channel A Reference 0.900V............: 1.010V
Channel B Reference 0.900V............: 1.010V
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Enabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
A noch zwei fragen bezüglich ::D
Soll ich dass so lassen?
Und :D
Channel A
Channel B Timings Settings
@ wien
hi mach mal folgendes.
auf standard
fixen auf 1.2V!
Fixen auf 1.5V!
kannst du auch auf 1.01V stellen
Ich würde den Ram 1:1 laufen lassen.
mach dafür folgendes:
auf 333 stellen
2.00B (es sollte der sein. achte dich einfach das bei memory frequency 830mhz steht)
bei Kanal a und b auf 10 stellen
Hab jetzt mein FSB von 266Mhz auf 300Mhz gestellt und lief bei 20min ORTHOS gut!
Keine Fehler!
Aber ist es normal wenn ich 72° bei einem Test habe?
Hab den normalen Intel Kühler!
Hab mir aber vor kurzem den Scythe Ninja 2 gekauft!
Ein riesen Ding aber der kühlt ja garnichts!
Mach ich da was falsch oder kühlt der von vornheraus nicht optimal bzw. nichts für
overclocken??
Wie weit meint ihr kann man den E7200 übertakten ohne dabei den VCore hochzudrehen?
Hab zurzeit 2,86Ghz von 2,53!
@ wien
wo kam der bluescreen? vorher war FSB termination auf auto und wurde vermutlich vom board selbst overvoltet. erhöhe mal die FSB termination auf 1,24-1,28
1,1V MCH könnte auch zu wenig sein erhöhe die MCH auf 1,2V.
an deiner stelle würde ich zuerst die mch auf 1,2V stellen und dann testen wenns läuft weiss du wo der fehler war. sonst erhöst du die fsb termination wie oben beschrieben.
Ich würde nicht beides auf einmal erhöhen. Einfach das du dann weisst wo das problem war. so lernst du auch dein board ein wenig kennen.
lass den ram teiler vorerst auf 1:1. mehr Ram takt als FSB bringt dir sowieso kein Leistungsplus. (ok ev belanglose 1-2 % ;) )
@ griprunner
ja mit dem intel kühler schon ;)
Aber sicher kühlt der ninja 2 und dann nicht zu knapp. hast du den auch richtig montiert? sprich: nicht zu viel/zu wenig wlp? den lüfter so montiert das er die luft von vorne nach hinten zieht?
wie weit der kommt ohne Vcore erhöhung musst du selbst rausfinden. ist immer verschieden aber ich denke so 3ghz könnten schon drin sein
gruss
Soweit so klar,
danke für diene tips:freaky:Envoy, habe nur MHC von 1.10V aufs 1.20V erhöht!
FSB(CPU)Termination ist auf 1.20V.
Ok, ich bin noch beim Testen .
Ram Teiler ist 1:1!
Hm, jetzt zur CPU PLL(ist 1.50V), bringt mir was, wenn ich eine Stufe hohe gehe !
Und noch zu meine offene frage von oben :
und vieleicht eine dummer frage( weil jeder CPU ist einzigartig, aber trotzdem).mein VID ist 1,250V, die Temps bei 3.5GHz ist ok(max 55Grad), Schafe ich mit meinem CPU 4GHz grenze(mit LUKU)?
Das kann dir keiner Sagen, das wirst du ausprobieren müssen,
WIEN schrieb:
( weil jeder CPU ist einzigartig, aber trotzdem)...
Und es kommt ja nicht nur auf die Temperaturen an sondern auch auf die Spannung an (klar, hängt natürlich auch zusammen).
Ich brauche für 3,4Ghz 1,225 (Bios), da bist du z.B. schon ne Ecke drüber für nur 100Mhz mehr...
geht das, was oben steht auch mit nem q6600 weil ihr ja alle nen anderen habt!!
naja ich werde den versuch erst starten, wenn mein neuer lüfter drin ist... da ich ja mit den temps nicht übertreiben will... und naja zu hohe temps sind ja au net gut....
wäre es für euch hilfreich wenn ich bilder von meim bios mache? dass ihr mir sagen könnt was ich umstellen muss!
wär au cool wenn es dann so weit ist, wenn mir dann einer in icq helfen würde oder so ;)
@ wien
CPU PLL könnte ev was bringen bei höherem FSB. Jezt noch nicht. (ich muss bei 500mhz FSB eine Stufe erhöhen auf 1,57V) Aber Vorsicht mit der PLL: Ja nicht höher als 1,6V sonst verabschiedet sich deine CPU früher oder später. eher früher ;)
lass diese einstellungen so. Ich weiss ehrlich gesagt auch nicht was sie bewirken.
da du die Vcore noch nicht erhöhen musstest sehe ich den 4ghz eher optimistisch entgegen ;)
einfach bei 75-80 grad mal stoppen :)
"Und es kommt ja nicht nur auf die Temperaturen an sondern auch auf die Spannung an (klar, hängt natürlich auch zusammen).
Ich brauche für 3,4Ghz 1,225 (Bios), da bist du z.B. schon ne Ecke drüber für nur 100Mhz mehr... "
3.4GHz habe ich mit 1.250 Stabil bekommen!mit weniger habe ich nicht getestet!Aber versuche du auf 3.5GHz zu gehn .dann muss du auch mehr V angeben:(.es sind nur "100MGh"aber trotzdem!:(
lol aus wien
Nö, ich lasse den so laufen.
Die 100Mhz mehr bringen mir gar nix, erst recht nicht wenn ich dafür dann noch die Spannung anheben müsste.
Zum benchen hatte ich die Kiste auch schon mal mit 4Ghz laufen, aber ob das stabil wirklich war, ka, die Werte waren alle Pi mal Daumen.
Benchstabil war es auf jeden Fall:D
Also ich hab im Bios jetzt erstmal NUR die fsb von 333 schrittweise auf 390 erhöt und er startet auch nur wenn ich den power knopf drücke leuhten alle leds auf gehen aus und anch 6sec fäährt er dann hoch =S
Wie gesagt nur Fsb geändert anschliessend lies ich prime laufen und erhielt exen fehlermeldungen (bericht senden Z/nicht senden von win) Eigentlich läuft alles stabil temps bleibenn imGrünen aber was solen die Fehlermeldungen etc warum fährt der langsam hoch
Sonstigen einstellunen (standart)
Mem Voltage; 2,10V
Cpu Voltage:1,300V
Muss ich die Spannung evtl noch erhöhen?? wenn ja umwiviel?
@ hardshocker
Naja wenn prime fehler meldet oder abschmiert ist das ding nicht stabil mein freund, sonst hätte prime keinen berechnungsfehle gemacht :D
ja Vcore erhöhen währe möglich. ich erhöhe sie immer gleich um 2 stufen um mir arbeit zu ersparen. (einfach insgesamt nicht mehr als 10% erhöhen)
Fixe noch die NB die SB und die FSB spannung auf den kleinsten wert.
@boir
Ja mit einem Mp3 player sollte das auch funktionieren
@ Envoy Ich habe keine ahnung vom übertakten bzw davon was ich mit "Fixe noch die NB die SB und die FSB spannung auf den kleinsten wert.Anzufangen habe xD um wiviel soll ich Vcore erhöhen? was soll ich tun??=D xDDDD
Aso ja hab jetzt die Cpu voltage von :1,35V auf 1,47V gestellt und lasse grad prime laufen:
Fan speed sagt mir der cpu wär 50 grad heiß aber core temp sagt mir 46 ° was soll ich glauben und ab wann sollte ich angst bekommen==??=S
Von 1,35 direkt auf 1,47?
Sportlich.
Was machst du denn wenn es dann immer noch nicht geht?
Direkt mal 1,7V oder wie?
Ganz ehrlich, du solltest dich wohl erst mal ein bisschen mit dem Thema beschäftigen bevor du wild und ohne Plan irgendwelche Spannungen verstellst...
naja deine sache, kein kommentar meinerseits. schau wenigstens auf die delta T werte in real temp oder Core temp ( options, settings, haken bei show delta to tjunktion max temp setzen) . die dürfen nicht uner 20 grad kommen. denn ich glaube nicht das deine cpu nur 50 grad wird mit 1,47V. das ist ein auslesefehler.
50grad in was? Idle? Omg
Les dir mal die Anleitungen durch.
2 Stufen sind nicht 1Volt. :rolleyes:
Sry aber so machst du deine Hardware nur schrott...
Status
