Head_Flying_Hours bedenklich?
linuxnutzer
Captain
Dez. 2011
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 225h+06m+07.385s
Ist das bedenklich?
Code:
~# smartctl -a /dev/sdb
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.14.0-33-generic] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Exos 7E8
Device Model:     ST8000NM000A-2KE101
Serial Number:
LU WWN Device Id: 5 000c50 0c0b3367c
Firmware Version: SN01
User Capacity:    8.001.563.222.016 bytes [8,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5894
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Oct 16 18:26:41 2025 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  559) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 732) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x70bd)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   078   064   044    Pre-fail  Always       -       63516863
  3 Spin_Up_Time            0x0003   092   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       211
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   078   060   045    Pre-fail  Always       -       70213910
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       837
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       211
 18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
190 Airflow_Temperature_Cel 0x0022   072   049   040    Old_age   Always       -       28 (Min/Max 26/28)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       26
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1950
194 Temperature_Celsius     0x0022   028   051   000    Old_age   Always       -       28 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   017   005   000    Old_age   Always       -       63516863
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       124130309420
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       87096869084
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%        11         -
# 2  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
Nein, das ist überhaupt nicht bedenklich. Deine HDD ist laut den SMART-Werten in einem Top-Zustand. Für eine Festplatte ist das eine vergleichsweise kurze Betriebszeit.
Reaktionen: ILoveShooter132, linuxnutzer und redjack1000
Das war Jahre eine Backup-HDD, die nur rumlag und wurde nun verbaut.
Ich habe die Hex-Werte umgerechnet, da ist nichts größer als 8 Stellen, aber bei den Head_Flying_Hours wurde ich unsicher.
Eine 2., gleichzeitig gekauft, ähnlich wenig benutzt, ist mausetot, gerade ein paar Monate nach Garantieablauf.
Alternate 1
