Smart: Was ist "220 Disk_Shift" ?
linuxnutzer
Captain
Dez. 2011
Nagelneue HDD;
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 18350082
Was ist das?
Code:
~# smartctl -a  /dev/sdc
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.14.0-29-generic] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Toshiba MG09ACA... Enterprise Capacity HDD
Device Model:     TOSHIBA MG09ACA18TE
Serial Number:
LU WWN Device Id: 5 000039 dc8d2bb4e
Firmware Version: 0107
User Capacity:    18.000.207.937.536 bytes [18,0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5894
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Oct  8 18:25:59 2025 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x80)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  120) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (1519) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       8973
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       1
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       0
 10 Spin_Retry_Count        0x0033   100   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1
 23 Helium_Condition_Lower  0x0023   100   100   075    Pre-fail  Always       -       0
 24 Helium_Condition_Upper  0x0023   100   100   075    Pre-fail  Always       -       0
 27 MAMR_Health_Monitor     0x0023   100   100   030    Pre-fail  Always       -       16713025
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       29 (Min/Max 17/30)
196 Reallocated_Event_Count 0x0033   100   100   010    Pre-fail  Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
222 Loaded_Hours            0x0032   100   100   000    Old_age   Always       -       0
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       668
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       0
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       10456
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
Der Wert gibt die Verschiebung der Plattern an. Sind übrigens kein einzelner Wert, sondern drei kleine, darum kommt die Zahl einem so hoch vor.
Ist normal.
Reaktionen: linuxnutzer
gaym0r schrieb:
Danke, wie analysiert man das? Ich nehme mal an, man muss es nach Hex konvertieren.
Code:
$ echo "obase=16; 18350082" | bc
1180002
Wie weiter?
Gibt es eine offizielle FW-Downlaod-Seite bei Toshiba?
gefunden habe ich: https://forums.servethehome.com/ind...mg09-how-to-upgrade-the-firmware.40130/page-2
und
https://files.hddguru.com/download/Firmware updates/Toshiba/?order=nom&direction=1
Zum einen will ich nichts inoffizielles und zum anderen scheint es, dass ich was neueres habe.
Wie schon gesagt wurde, nicht schlimm.
Es zeigt einfach auf, dass der Platter bzw. Lese/Schreibköpfe etwas gedriftet sind. Das kann an Temperatur-Ausdehnung, Schock oder andere Ursachen liegen. Im Auge behalten wenn sich in den nächsten ~100h nichts ändert würde ich mir kein Kopf machen. HDDs fallen entweder in den ersten Stunden aus oder laufen zehntausende Stunden ohne Probleme.
Trotzdem gilt 3-2-1 Backups!
Reaktionen: whats4 und linuxnutzer
Verpackung war wie üblich schlecht, aber:
Das sieht doch gut aus, oder?
Ich weiß noch nicht wie ich die HDD nutzen soll. Die ist für ein Backup gedacht und dann liegt sie rum, das dauert keine 100h. Ich mache mal bis morgen(?) einen langen Smart Test. Könnte sein, dass ich nicht auf das Datum geschaut habe und nur auf die Uhrzeit.
Extended self-test routine recommended polling time: (1519) minutes.
Reaktionen: Cool Master
Der G-Sense... löst nur im Betrieb aus nicht wenn die HDD aus ist. Wie gesagt ich würde mir aktuell kein Kopf machen da alles super aussieht und im Gegensatz zu Seagate wohl auch wirklich neu ist :D
Leicht gesagt, es geht um eine HDD, die 1x zu 3/4 voll wird und sich danach kaum ändert. Die letzte wurde nach etwas über 5 Jahren defekt, obwohl fast neu.
Ich habe die jetzt ein wenig geprüft:
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 48 (Min/Max 17/49)
Die wurd aksi gabt schön warm.
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 1835010
27 MAMR_Health_Monitor 0x0023 100 100 030 Pre-fail Always - 69215
Dezimal gesehen sind beide Werte niedriger geworden.
Code:
Serial Number:
Local Time is:    Fri Oct 10 18:34:08 2025 CEST
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       48
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       3
222 Loaded_Hours            0x0032   100   100   000    Old_age   Always       -       46
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       610
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       35156656128
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       27270425
No Errors Logged
# 1  Extended offline    Completed without error       00%        23         -
# 2  Short offline       Completed without error       00%         0         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Geschwindigkeitstests:
Code:
# hdparm -T /dev/sdc
/dev/sdc:
 Timing cached reads:   56228 MB in  1.98 seconds = 28346.63 MB/sec
Code:
# hdparm -t /dev/sdc
/dev/sdc:
 Timing buffered disk reads: 776 MB in  3.00 seconds = 258.32 MB/sec
Code:
# dd if=/dev/zero of=/dev/sdc1 bs=1M count=1024 conv=fdatasync,notrunc
1024+0 Datensätze ein
1024+0 Datensätze aus
1073741824 Bytes (1,1 GB, 1,0 GiB) kopiert, 4,36732 s, 246 MB/s
Also 258 MB/sec lesen und 246 MB/s schreiben. Test war auf eine komplett leere 18TB-Partition mit xfs, wbei die Partition dann durch den Test überschrieben wurde.
Temp. ist vollkommen ok. HDDs mögen so ~45°C als optimal Temp. können aber auch mehr.
Wie gesagt ich würde mir kein Kopf machen. Entweder die HDD schmiert in den ersten Stunden/Tagen oder sie hält ewig. 5 Jahre ist für eine HDD durchaus ok. Kommt halt immer drauf an was damit gemacht wird.
Habe sowieso keine Alternative. Ich sichere gerade.
Ich meine 5 Jahre rumliegen, die wurde nur ganz wenig genutzt. Vielleicht weniger als 100h. Ich habe ja wieder die gleiche Situation. Multimedia ändert sich nicht, da kommt auch bei mir kaum was dazu. Ich sichere nur, wenn es schmerzen würde, wenn ich die Änderung verlieren würde, also ganz sporadisch. Notfalls findet man eine TV.Aufnahme auch bei Youtube, muss aber suchen.
Ja eben, nämlich nichts. Einmaliger Datenspeicher.
Einfach Regelmäßig anschalten und ein paar Stunden laufen lassen. Im besten Fall ein langen SMART Test machen, dann passt das auch.
Power on Hours:
Wie der Name schon sagt, die Anzahl der Stunden, die das Gerät insgesamt eingeschaltet war.
Load in Time:
Herstellerabhängig – idR die Zeit in (Mili)Sekunden, die die Festplatte braucht, um nach einem "Load" (z. B. nach Standby) betriebsbereit zu sein.
Loaded Hours:
Die Zeit (in Stunden), in der die Festplatte tatsächlich im "geladenen" Zustand war – also bereit, Daten zu lesen/schreiben.
Spin Up Time:
Zeit, die die Festplatte benötigt, um auf Betriebsdrehzahl hochzufahren (in Millisekunden).
na lass sich doch 100/200 stunden laufen, was spricht dagegen?
wurscht, ob dein backup schon fertig is.
weil du willst ja wissen, ob gut funktioniert.
und sorge dafür, daß sie was tut. ned exzessiv, aber halt "was", sprich: lass dir eine temporärnuzung einfallen.
und wennst für ein paar tage den temp ordner hinschiebst/generierst.
wasauchimmer, und wennst den eindruck hast, daß es stable rennt, kübelst das wieder.
@linuxnutzer
Da besorgt man sich Linux 😅 mit badblocks und läst das mal laufen ;)
Das ist ein richtiger Test. Bei der Plattengröße dauert der bestimmt an die 4/5 Tage
Dabei schauen, dass die Platte um die 40°C behält.
Wenn die Platte nicht mal das überleben würde, wäre die eh schon vorgeschädigt gewesen.
Den sth Thread hast du gelesen? Da tut niemand eine HDD Firmware irgendwie basteln.
Das ist schon ein wenig gelaufen.
1 Schreib- und 1 Lesedurchgang.
1 Durchgang 24h, also die 4 Standard 4 Tage.
Unmöglich, es waren 50°.
badblocks ist normalerweise mein Standard-Burnin-Test. Aber dieses Mal wird es mir auf Dauer zu heiß.
Alternate 1
