CoMo
- Dez. 2015
Hallo,
ich habe hier gerade einen Futro S920 ThinClient mit Kubuntu ausgestattet.
Der PC bootet in ein schwarzes Bild. Mit
Was für einen Treiber o.ä. brauche ich da jetzt?
nomodeset geht es.Was für einen Treiber o.ä. brauche ich da jetzt?
Code:
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Mullins [Radeon R4/R5 Graphics] (rev 06)
Code:
# dmidecode 3.5
Getting SMBIOS data from sysfs.
SMBIOS 2.8 present.
55 structures occupying 2362 bytes.
Table at 0xDAEC9018.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: FUJITSU // American Megatrends Inc.
Version: V4.6.5.4 R1.16.0 for D3313-G1x
Release Date: 08/13/2018
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 8 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.16
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: FUJITSU
Product Name: FUTRO S920
Version:
Serial Number: YLUE124881
UUID: e63b5865-51fc-11e8-8782-901b0efad7b2
Wake-up Type: AC Power Restored
SKU Number: S26361-Kxxx-Vyyy
Family: FUTRO-FTS
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: D3313-G1
Version: S26361-D3313-G1
Serial Number: 56257176
Asset Tag:
Features:
Board is a hosting board
Board is replaceable
Location In Chassis:
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 25 bytes
Chassis Information
Type: Desktop
Lock: Not Present
Version:
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 1
<OUT OF SPEC> (0)
SKU Number: To be filled by O.E.M.
Handle 0x0004, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: Nuvoton
Internal Connector Type: None
External Reference Designator: PS/2 Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0005, DMI type 8, 9 bytes
External Reference Designator: PS/2 Keyboard
Port Type: Keyboard Port
Handle 0x0006, DMI type 8, 9 bytes
Internal Reference Designator: SMsC
External Reference Designator: Serial-1
External Connector Type: DB-9 male
Port Type: Serial Port 16550 Compatible
Handle 0x0007, DMI type 8, 9 bytes
External Reference Designator: Serial-2
Handle 0x0008, DMI type 8, 9 bytes
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Reference Designator: Serial-3
External Connector Type: None
Handle 0x0009, DMI type 8, 9 bytes
Internal Connector Type: 25 Pin Dual Inline (pin 26 cut)
External Reference Designator: Parallel
Port Type: Parallel Port ECP/EPP
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: Realtek
External Reference Designator: LAN
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: HD8330E
External Reference Designator: DVI-I
External Connector Type: Other
Port Type: Video Port
Handle 0x000C, DMI type 8, 9 bytes
External Reference Designator: Display Port
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: ALC671
External Reference Designator: Rear: Line-Out
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: Rear: Line-In
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: Front: Line-Out
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: Front: Mic-In
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: GX-415GA
External Reference Designator: Rear: USB-1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
External Reference Designator: Rear: USB-2
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
External Reference Designator: Rear: USB-3
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: Rear: USB-4
Port Type: USB
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: Front: USB-1
Port Type: USB
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: Front: USB-2
Port Type: USB
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: Intern: USB-1
Port Type: USB
Handle 0x0018, DMI type 8, 9 bytes
Internal Connector Type: SAS/SATA Plug Receptacle
External Reference Designator: SATA-0
Port Type: None
Handle 0x0019, DMI type 8, 9 bytes
Internal Connector Type: Other
External Reference Designator: mSATA
Port Type: None
Handle 0x001A, DMI type 8, 9 bytes
External Reference Designator: mPCIe
Port Type: None
Handle 0x001B, DMI type 8, 9 bytes
External Reference Designator: TPM HDR
Port Type: None
Handle 0x001C, DMI type 9, 17 bytes
System Slot Information
Designation: PCIe
Type: x4 PCI Express 2 x16
Current Usage: Unknown
Length: Short
Characteristics:
3.3 V is provided
PME signal is supported
Bus Address: 0000:00:00.0
Handle 0x001D, DMI type 10, 16 bytes
On Board Device 1 Information
Type: Other
Status: Enabled
Description: SMsC SCH5627 Super I/O
On Board Device 2 Information
Type: Other
Status: Enabled
Description: Nuvoton NCT5571D Super I/O
On Board Device 3 Information
Type: Sound
Status: Enabled
Description: Realtek ALC671
On Board Device 4 Information
Type: Video
Status: Enabled
Description: HD8330E
On Board Device 5 Information
Type: Other
Status: Enabled
Description: Antiope
On Board Device 6 Information
Type: Ethernet
Status: Enabled
Description: Realtek RTL8111G
Handle 0x001E, DMI type 11, 5 bytes
OEM Strings
String 1: FUJITSU
String 2: FUJITSU
String 3: FUJITSU TECHNOLOGY SOLUTIONS
Handle 0x001F, DMI type 12, 5 bytes
System Configuration Options
Option 1: J3-5: Default position
Option 2: J1-2: Reserved
Option 3: J5-6: Recovery BIOS active
Handle 0x0026, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Not Implemented
Administrator Password Status: Disabled
Front Panel Reset Status: Not Implemented
Handle 0x0027, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0028, DMI type 41, 11 bytes
Onboard Device
Reference Designation: SMsC SCH5627 Super I/O
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 00ff:ff:1f.7
Handle 0x0029, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Nuvoton NCT5571D Super I/O
Type: Other
Status: Enabled
Type Instance: 1
Handle 0x002A, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek ALC671
Type: Sound
Status: Enabled
Type Instance: 1
Handle 0x002B, DMI type 41, 11 bytes
Onboard Device
Reference Designation: HD8330E
Type: Video
Status: Enabled
Type Instance: 1
Handle 0x002C, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Antiope
Type: Other
Status: Enabled
Type Instance: 1
Handle 0x002D, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek RTL8111G
Type: Ethernet
Status: Enabled
Type Instance: 1
Handle 0x002E, DMI type 15, 77 bytes
System Event Log
Area Length: 16383 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: Memory-mapped physical 32-bit address
Access Address: 0xFFC46000
Status: Valid, Not Full
Change Token: 0x00000002
Header Format: Type 1
Supported Log Type Descriptors: 27
Descriptor 1: Single-bit ECC memory error
Data Format 1: Multiple-event handle
Descriptor 2: Multi-bit ECC memory error
Data Format 2: Multiple-event handle
Descriptor 3: Parity memory error
Data Format 3: None
Descriptor 4: Bus timeout
Data Format 4: None
Descriptor 5: I/O channel block
Data Format 5: None
Descriptor 6: Software NMI
Data Format 6: None
Descriptor 7: POST memory resize
Data Format 7: None
Descriptor 8: POST error
Data Format 8: POST results bitmap
Descriptor 9: PCI parity error
Data Format 9: Multiple-event handle
Descriptor 10: PCI system error
Data Format 10: Multiple-event handle
Descriptor 11: CPU failure
Data Format 11: None
Descriptor 12: EISA failsafe timer timeout
Data Format 12: None
Descriptor 13: Correctable memory log disabled
Data Format 13: None
Descriptor 14: Logging disabled
Data Format 14: None
Descriptor 15: System limit exceeded
Data Format 15: None
Descriptor 16: Asynchronous hardware timer expired
Data Format 16: None
Descriptor 17: System configuration information
Data Format 17: None
Descriptor 18: Hard disk information
Data Format 18: None
Descriptor 19: System reconfigured
Data Format 19: None
Descriptor 20: Uncorrectable CPU-complex error
Data Format 20: None
Descriptor 21: Log area reset/cleared
Data Format 21: None
Descriptor 22: System boot
Data Format 22: None
Descriptor 23: End of log
Data Format 23: None
Descriptor 24: OEM-specific
Data Format 24: OEM-specific
Descriptor 25: OEM-specific
Data Format 25: OEM-specific
Descriptor 26: OEM-specific
Data Format 26: OEM-specific
Descriptor 27: OEM-specific
Data Format 27: OEM-specific
Handle 0x0031, DMI type 176, 36 bytes
OEM-specific Type
Header and Data:
B0 24 31 00 00 00 13 33 00 39 03 00 03 31 FF FF
42 3E 0D 11 DA 8D D4 49 A4 98 8C 4B EF BF BA BB
02 00 02 00
Handle 0x0032, DMI type 177, 42 bytes
OEM-specific Type
Header and Data:
B1 2A 32 00 12 00 00 00 12 00 00 00 12 04 06 05
04 01 10 00 00 00 00 00 00 00 00 12 00 00 00 00
00 00 00 00 00 00 00 00 00 00
Handle 0x0033, DMI type 188, 8 bytes
OEM-specific Type
Header and Data:
BC 08 33 00 30 39 31 24
Handle 0x003C, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x003D, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x001FFFFFFFF
Range Size: 8 GB
Physical Array Handle: 0x003C
Partition Width: 255
Handle 0x003E, DMI type 17, 40 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 2
Bank Locator: CHANNEL A
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 1600 MT/s
Manufacturer: Hynix/Hyundai
Serial Number: 0326C7BF
Asset Tag: A1_AssetTagNum0
Part Number: HMT451S6BFR8A-PB
Rank: 1
Configured Memory Speed: 1600 MT/s
Minimum Voltage: 1.35 V
Maximum Voltage: 1.5 V
Configured Voltage: 1.5 V
Handle 0x003F, DMI type 17, 40 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 1
Type: DDR3
Speed: 1600 MT/s
Serial Number: 0346C7AB
Asset Tag: A1_AssetTagNum1
Rank: 1
Handle 0x0040, DMI type 20, 35 bytes
Memory Device Mapped Address
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x003E
Memory Array Mapped Address Handle: 0x003D
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x0041, DMI type 20, 35 bytes
Starting Address: 0x00100000000
Range Size: 4 GB
Physical Device Handle: 0x003F
Handle 0x0043, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 CACHE
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 128 kB
Maximum Size: 128 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 2-way Set-associative
Handle 0x0044, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 CACHE
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 1 MB
Maximum Size: 1 MB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Handle 0x0045, DMI type 4, 42 bytes
Processor Information
Socket Designation: P0
Type: Central Processor
Family: G-Series
Manufacturer: AuthenticAMD
ID: FF FB 8B 17 01 0F 73 00
Signature: Family 11, Model 15, Stepping 15
Flags:
FPU (Floating-point unit on-chip)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
DS (Debug store)
ACPI (ACPI supported)
Version: AMD GX-222GC SOC with Radeon(TM) R5E Graphics
Voltage: 1.4 V
External Clock: 100 MHz
Max Speed: 2200 MHz
Current Speed: 2200 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x0043
L2 Cache Handle: 0x0044
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0046, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 2
en|US|iso8859-1
ja|JP|unicode
Currently Installed Language: en|US|iso8859-1
Handle 0x0049, DMI type 127, 4 bytes
End Of Table
