Pc Blue Screen:Schwerwiegender Hardwarefehler.Komponente: ArbeitsspeicherFehlerquelle: Machine Check Exception
GamerLLit
Cadet 2nd Year
Mai 2024
Hallo ich habe seit einiger zeit ständige blue screens als fehlermendung in der Eriegnisanzeige bekomme ich immer nur:
was ich schon gemacht habe:
windows clean install (per usb stick)
ram ausgetauscht
stress test für gpu und cpu
windows diagnosetool für ram
alle treiber installiert
anbei noch ein paar weitere infos:
minidump im windows ordner:
https://drive.google.com/file/d/1h6_X2Vq3y5uq942onAdePxzqG8yHRbjm/view?usp=sharing
+System
-Provider
[ Name]Microsoft-Windows-WHEA-Logger
[ Guid]{c26c4f3c-3f66-4e99-8f8a-39405cfed220}
EventID46
Version0
Level2
Task0
Opcode0
Keywords0x8000000000000000
-TimeCreated
[ SystemTime]2024-05-29T16:51:24.9638624Z
EventRecordID6292
-Correlation
[ ActivityID]{54730df4-68da-49e2-bf26-cb14e1ccd67c}
-Execution
[ ProcessID]5316
[ ThreadID]5784
ChannelSystem
ComputerTill-Pc
-Security
[ UserID]S-1-5-19
-EventData
ErrorSource3
FRUId{00000000-0000-0000-0000-000000000000}
FRUText
ValidBits0x2
ErrorStatus0x0
PhysicalAddress0x18776d8c0
PhysicalAddressMask0x0
Node0x0
Card0x0
Module0x0
Bank0x0
Device0x0
Row0x0
Column0x0
BitPosition0x0
RequesterId0x0
ResponderId0x0
TargetId0x0
ErrorType0
Extended0
RankNumber0
CardHandle0
ModuleHandle0
Length1019
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
Aha, ...
..., und welche Hardware steckt im PC? Mit welchem Takt werden RAM und CPU betrieben?
4 ram riegel?
also verbaut sind:
Motherboard:GIGABYTE B550 AORUS ELITE AX V2 rev 1.3
Gpu:GIGABYTE GeForce RTX 3070 GAMING OC 8G 2.0 (GV-N3070GAMING OC-8GD)
Cpu:AMD Ryzen 5 5600X
Ram:CMK32GX4M2E3200C16 läuft über xmp profil mit 3200mhz (2 Riegel je 16 gb)
In welchen Steckplätzen steckt der RAM? Von der CPU aus gesehen.
Den Speicher mit einem Programm wie memtest86+ testen.
Ist das BIOS Mainboards aktuell? Gegebenenfalls mit HWiNFO auslesen.
Reaktionen: Baal Netbeck
ram sitzt im 2. und 4. slot
bios auf neuster version (FF)
Wie lange soll ich Memtest laufen lassen?
Bis der Test abgeschlossen ist oder die ersten Fehler auftauchen.
Wenn Fehler auftauchen sollte, die Riegel einzeln im zweiten Slot testen.
alles klar werd ich über die nacht machen und mich dann nochmal melden
so ich habe jetzte den memtest über nacht laufen lassen ohne probleme also keine errors.
zu den problemen kommt es meist wenn ich spiele spiele aber auch oft einfach so während ich videos schaue
Ich gehe davon aus, dass CPU und Arbeitsspeicher in Ordnung sind.
Von dir wurden alle Treiber aktualisiert? Welche genau und wie bist du vorgegangen?
Ich frage nur deswegen, da in der Vergangenheit schon einige Nutzer Hilfen wie "Driver Booster", "Snappy Driver Installer" genutzt haben, um ihr System auf einen aktuellen Stand zu bringen, sich damit aber ihr Windows zerschossen haben.
ich hab mir die nvidia app für meine GPU geholt und den neusten treiber installiert, dann hab ich über die amd seite die neusten chipset treiber installiert und windows auf den neusten stand geupdatet
Ich hätte eine andere Reihenfolge gewählt:
  • Alle Windows-Updates durchlaufen lassen
  • Installation der AMD-Chipsatztreiber
  • Installation der Nvidia-Treiber von Hand ohne die Nutzung der App von Nvidia.
  • gegebenenfalls noch Audio- und Netzwerktreiber passend zum Mainboard bei Gigabyte herunterladen und installieren.
Wenn das Problem auch beim Abspielen von Videos auftritt: Werden die Videos fehlerfrei abgespielt, wenn die Basistreiber für die Grafik genutzt werden, soll heißen vor Installation der Nvidia-Treiber?
Besteht die Möglichkeit, den PC mit einer anderen Grafikkarte zu testen?
ich habe gerade keine andere grafikkarte zuhause also das geht leider nicht. Was soll ich deiner meinung jetzt tun?
Da muss ich aktuell passen, vielleicht hat noch irgendjemand anderes eine Idee.
ich habe ja prime95 stresstest laufen lassen vielleicht deswegen
oh ok kenn mich da erlich gesagt nicht so gut aus was sollte ich denn tun um meine cpu zu überprüfen?
